I saw in this topic that XnViewMP supports .KRA files. Krita thumbnails are displayed correctly on my machine (Windows 7 x64, XnViewMP 0.96), but double-clicking a thumbnail opens the file in Krita, not XnViewMP. Is that the intended behavior? If not, how may I fix it?
Krita support?
Re: Krita support?
Find a .KRA file. Right click it, choose "open with" and choose XnView and make sure "always open with" is checked
Rick
Rick
Re: Krita support?
Thanks, that worked the first time, but after I closed XnViewMP, now it has reverted to being unable to display thumbnails and being unable to open the files.
Re: Krita support?
Does it always open correctly in Windows explorer? If so you set it up correctly now in XcView try opening it with F3 rather than double clicking
Rick
Rick
Re: Krita support?
Ugh. Okay, sorry, I think I just had a case of the Schrödinger’s bug right now… You know, the one where you try to reproduce a problem so you can document it for someone, but suddenly everything works fine? Anyway, yeah, it works now. Thanks!
