0.96.1 x64 on Windows 10 x64
Thumbnails formerly showed the checkerboard background to indicate transparent areas
It has disappeared in this version
0.96.1 Transparency not shown in PNG thumbnails
Rick
Re: 0.96.1 Transparency not shown in PNG thumbnails
you had it in 0.96?
Akovia
Yeah, but it must be something specific about the files. Here are 2 side by side and one shows the transparency fine and the other doesn't.
Arch Linux
XnView MP
XnView MP
which version has that, there is no checkerboard for thumbnail
Akovia
o.96.1 which is why I posted here instead of starting a new thread.
I've never experienced (AFAICR) any png thumbnail not showing a checked background until this update. What was strange is that some pngs still show checks but some don't.
Arch Linux
XnView MP
XnView MP
but which version do you had with checkedboard??Akovia wrote: Sun Apr 26, 2020 3:43 pm o.96.1 which is why I posted here instead of starting a new thread.
Akovia
AFAICR = As far as I can remember.
I don't ever recall running into a png file that didn't have a checkered background until I ran into this example the other day. When I searched the forums for the issue, I ran into this post and figured it was related as I had just upgraded my version as well from 0.96 > 0.96.1.
When I get a chance (hopefully today) I'll roll back my version and see if 0.96 is acting the same way with this particular file. I didn't do this because it really seemed related since someone else had the exact same problem after the recent update.
Arch Linux
XnView MP
XnView MP
Akovia
hmm, it looks like I can't downgrade easily. I checked my existing packages on my system and the only other version I have is xnviewmp-0.76.1-2-x86_64.pkg.tar.xz
I have only run into that one image so far so it's not a huge problem. If I run into any more I will certainly post them here.
Arch Linux
XnView MP
XnView MP
You should be able to download more versions if you wish to test them from this link: Old versions.
Akovia
Sorry but that is giving me an error when I try.cday wrote: Mon Apr 27, 2020 8:13 pm You should be able to download more versions if you wish to test them from this link: Old versions.
$ ./xnview.sh
qt.qpa.plugin: Could not load the Qt platform plugin "xcb" in "" even though it was found.
This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Available platform plugins are: linuxfb, minimal, minimalegl, offscreen, vnc, wayland-egl, wayland, wayland-xcomposite-egl, wayland-xcomposite-glx, xcb.
Aborted (core dumped)Arch Linux
XnView MP
XnView MP
