XnView: 0.96 64bits (Mar 20 2020)
(Also in XnConvert)
1. launch the convertor
2. action: replace color
3. select source color, and open the built-in colorpicker
4. after color selection, the RGB values are false and the color is darkened.
Actual behaviour (bug): RGB=113,119,113
Expected behaviour: RGB=132,138,132 (from the macOS colorpicker in the Applications/Utilities)
NB: color is picked from the source-preview
0.96: darker RGB values from the built-in colorpicker
Rajah
Re: 0.96: darker RGB values from the built-in colorpicker
Right, seems to be a bug in QT API, i'll ask the team...
Rajah
Sorry, I forgot the macOS version : 10.14.6 (18G2022)
Pierre
Pierre
