Folder name not updated in dialog "Choose folder"
When using Batch conversion, one can choose an output folder using the "..." button. The subdialog "Choose folder" opens up.
After pressing "New folder" button, a new folder is created and shown in the tree, selected and ready for renaming, which is good.
After renaming, the field "Folder" still says "New folder" (Bug 1).
Now, if you select the folder that you have just created and create another subfolder, the folder will be created, but it's not selected (Bug 2, might be related to Bug 1).
Re: Folder name not updated in dialog "Choose folder&qu
helmut wrote:When using Batch conversion, one can choose an output folder using the "..." button. The subdialog "Choose folder" opens up.
It's not XnView :-) but windows API...
Re: Folder name not updated in dialog "Choose folder&am
Are you sure? The new folder button looks pretty much like a non-Windows button.
Yes :-)
