I choose this setting :
Categories menu > Action > Assign Category (instead of Open Tree )
Now I when type a few letters I find the category I want to assign, I can click on it, it will be assigned OK
But the metadata setting "Apply parent keywords" is not used ... so parent categories are not enabled ...
Action Category Menu Assign [Solved]
Catalogage avec XnviewMP :
Re: Action Category Menu : Assign
ok right
it's fixed in latest version, right?
Yes, fixed
Merci Pierre
Merci Pierre
