0.96.2. W10 non stability of size of information window in full screen
J97
Post by J97 »
Hello
I am using v0.96.2. on W10.
In settings (english translation by me as I am using French menus)
View/Full screen/Automatic size : adjust to the window
Vue/Plein écran/Taille automatique : ajuster à la fenêtre
View/Full screen/See the informations : selected
Vue/Plein écran/Voir les informations : sélectionné
View/Full screen/Show the reading bar : selected
Vue/Plein écran/Montrer la barre de lecture : sélectionné
Floating views : selected
Vues flottantes : sélectionné
What I noticed :
  • opening the full view the first time of a session seems good : we have the same functionnality as for example with FastToneImageViewer with an information windows that appears (pop up) when the mouse is put at the right end of the window
  • the width of the information popup window can be modified, but not the height ? (could it be ? useful as histogram is "lost" at the bottom when displayed ....)
  • when switching auto hide button at the right top corner of the popup windows, it shares the screen with the image : that's OK
  • but, when closing and reopening the full view a certain number of times (by clicking on the mouse to open), the size (width) of the popup information windows seems erratic and random ?
    • When in floating mode, it covers up to half of the image and is displayed automatically without right positionning of the mouse ?!? then having to resize and close it to view the image
    • when in static display mode, it covers up to full width of the image ?!?, then having to resize it to display correctly the image
I have tried to modify setting to avoid such problems, but it looks to be a little bug as the function seems ramdomly working for the information window.
Re: 0.96.2. W10 non stability of size of information window in full screen
could you post some screenshots, please?
J97
Post by J97 »
How can I post screenshots in the forum ? I need a web hosting as I have to indicate an url for the image ?
Is there a way to import some image in the forum ?
J97 wrote: Sat May 09, 2020 1:27 pm How can I post screenshots in the forum ? I need a web hosting as I have to indicate an url for the image ?
Please see this tutorial...
Current forum attachment size limit is 2MiB, some less common formats can only be attached in a ZIP or similar archive.
Larger files, shouldn't be needed for a screenshot as a PNG or JPEG, can be uploaded to an image hosting service, preview the post to ensure that images placed between Img tags are correctly inserted and do actually display.
J97
Post by J97 »
J97
Post by J97 »
J97
Post by J97 »
J97
Post by J97 »
Remarque :
- à chaque fois, j'utilise le positionnement de la souris à droite pour afficher la fenêtre en mode popup
- IMPORTANT !! visiblement, le souci apparaît lorsqu'on a, une fois auparavant, affiché en mode popup le bandeau des vignettes ! .... quand on ne l'affiche pas dans la session en cours, je n'arrive pas à reproduire le souci. Il y a peut être une liaison ...
J97
Post by J97 »
Je confirme, le souci n'apparait pas quand on évite d'afficher le bandeau des vignettes....
Je n'ai pas trouvé dans les options comment ne pas l'afficher :-(
J97 wrote: Sat May 09, 2020 3:32 pm - à chaque fois, j'utilise le positionnement de la souris à droite pour afficher la fenêtre en mode popup
Je n'arrive pas à reproduire le 3eme affichage, c'est plein depuis l'explorateur ou depuis l'editeur?
J97
Post by J97 »
Curieux, je l'ai reproduit plusieurs fois sur 2 PCs différents.
Je peux faire une capture live .... mais pas avant qq jours (pas mal de boulot).
A chaque fois, je pars de l'explorateur en faisant clic molette souris pour avoir l'affichage plein écran, et si au moins une fois j'ai mis la souris vers le haut dans la session sur cette vue (pour afficher le ruban des vignettes), alors la fenêtre d'informations s'agrandit.
Remarque : ce n'est pas un comportement malheureusement réellement systématique. Le seul point commun que j'ai pu trouver, c'est l'affichage au moins une fois dans la session du ruban supérieur (quand on déplace la souris vers le haut).
J97 wrote: Mon May 11, 2020 10:34 pm Curieux, je l'ai reproduit plusieurs fois sur 2 PCs différents.
Oui je veux bien merci
J97
Post by J97 »
A quelle adresse mail pour un WeTransfer ?
J97 wrote: Thu May 14, 2020 3:19 pm A quelle adresse mail pour un WeTransfer ?
webmaster at xnview dot com
J97
Post by J97 »
OK
Je prépare cela et je l'envoie d'ici ce soir.
