Way to view JPEG estimated quality?
Is there a way to view the estimated quality of a JPEG, as in XnView MP?
Re: Way to view JPEG estimated quality?
you should have it
in info pane (browser mode)
One would expect to see it in the Viewer Info display, easily accessible using the 'I' shortcut key...
I recommended Classic to an elderly friend, after considering a number of alternatives, because I thought it would be easier for him to use for his limited needs, and I need to be able to give him simple instructions.
I normally use 'MP myself now, because it is better overall, and as I'm normally in Linux and dislike booting into Windows 10.
