Print Size : Inch or cm by default
B.Douille
Post by B.Douille »
In the Image Resize dialog, the default option for Print Size is always Inch. Can this be linked to the setting in General > General > "Use Inch for print size"?
It's just painful to have to change it again each time you re-enter the dialog in the same session.
Thank's in advance
PS: Same behavior with XnView Classic, except the value is kept during a session but reset to Inch when the application is started again. Posted in topic viewtopic.php?f=34&t=25325&p=162876&hil ... ic#p162876
Daniel, happy user for 20 years, to manage photo and videos and share them in slideshows (Windows 11, Linux Ubuntu and Android)
Re: Print Size : Inch or cm by default
If you use 'Last used', last settings are restored (print size too). Perhaps a checkbox to always restore last values?
B.Douille
Post by B.Douille »
Hello Pierre,
The "Last use" choice in the drop-down list on the top is useful only if you run into multiple changes with same output. When resizing a single picture this doesn't work (and going to this drop-down is as painful as the other). You may also have to resize another picture during the same session, of a different size and completely different resize settings.
May I suggest to use automation and auto-adaptation ? The print-size in Inch or cm highly depends on the habits of the user, the country, the culture,... It should be saved independently of the setting on the top drop-down-list. Doing so it's automatically restored on the next use of the app.
PS: I'm not fan of adding a new option a new checkbox. Today's design is soft and clean, minimalist (being an X generation, I should admit it's even sometime too much for me :wink: ). A new user should not find the application painful and complex due to too-many options. Look simple upfront, moving complexity behind the scene. That's what Apple pretends, led to success in the past and still reputation (even if no more true or unique - my opinion)
B.Douille
Post by B.Douille »
xnview wrote: Mon Jul 20, 2020 6:55 am If you use 'Last used', last settings are restored (print size too). Perhaps a checkbox to always restore last values?
"Last used" in the drop down doesn't help and I'm not fond of adding a new checkbox.
My suggestion is to link this with the setting in General > General > "Use Inch for print size"?
Perhaps my previous post was too long to read :) My (bad) habits.
