0.96.2, 64 bit, Starting the app categories filter pane is empty
nji9
Post by nji9 »
Well, the subject says it all...
If I start XnViewMP while the categories filter pane has been activated, the latter is completely empty.
If I switch to another pane, and then back to categories filter all is shown (Rating, Colour Label etc.)
Win7Prof 64 bit
Re: 0.9.2, 64 bit, Starting the app categories filter pane is empty
you can reproduce at each startup?
nji9
Post by nji9 »
Yes. At evey XnView's startup.
I even did a Win startup in-between (you never know).
Would like to annotate that only yesterday I installed XnView
for the very first time ... so wouldn't have occation to damage too much since...
Can't you reproduce?
nji9
Post by nji9 »
... one more annotation:
I do as non-admin...
on windows 10, i can't. please try to rename the xnview.ini?
nji9
Post by nji9 »
xnview wrote: Thu May 14, 2020 2:52 pm on windows 10, i can't. please try to rename the xnview.ini?
It's (only) located in my user folder.
I have full access.
No problems in renaming.
nji9 wrote: Thu May 14, 2020 3:53 pm
I have full access.
and if you restart?
nji9
Re: 0.96.2, 64 bit, Starting the app categories filter pane is empty
Post by nji9 »
Oh, I thought you had a rights problem in mind, so re-re-named before start.
OK, rename, start => produces a new ini (14k, instead of 17k), error gone.
Strange, I absolutely did no mystic things in that one day since installation.
nji9
Post by nji9 »
It worked for some time.
Then, without having done anything "unusual" in the last session,
when restarting the pane is empty again
is it possible to have your xnview.ini?
nji9
Post by nji9 »
Sent as pm
nji9 wrote: Fri May 15, 2020 1:01 pmSent as pm
Strange, in the settings, 'category filter' panel is not visible, if i use your settings on Win7, at first startup the 'category filter' is empty, but as soon as i click on 'Folder' tab and 'Category filter', and quit, all will be ok on next startup...
nji9
Post by nji9 »
Yes, I make the same experience:
Sometimes (most times) it is not there, sometimes it is there again.
Only one thing is for sure:
If I SWITCH TO the categories pane, it is never empty.
The effect only occurs (sometimes) when starting up MP and the pane is activated already.
Maybe of any help for you?
Alexandra0056
Post by Alexandra0056 »
Can confirm on XnView MP 1.8.8
I can't confirm it on newer version because PortableApps.com didn't released yet XnView MP 1.9.2, so I apologise for that, but I firmly believe that 1.9.2 is affected too.
It's really annoying, so I hope that it will be fixed soon. And it is called Catalog Filter, not Categories Filter.
Screenshot showing the issue:
Best regards, Alexandra.
Alexandra0056 wrote: Thu Jun 12, 2025 12:01 pm I can't confirm it on newer version because PortableApps.com didn't released yet XnView MP 1.9.2, so I apologise for that, but I firmly believe that 1.9.2 is affected too.
could you send us your xnview.ini?
