Newby question: filter on file type
nji9
Post by nji9 »
I have been trying and searching... but to no success... so I ask:
I would like to filter the results of my categorized items by "item type"
I don't mean 1 extension, but a set of respectively (imges = jpg, jpeg, tif, pcx etc.).
In the filter dialog I can choose some predefined (for example images, videos, ...),
although it seems buggy all over viewtopic.php?f=62&t=40459
But I would like to define my own sets of filtering (see "documents" = doc docx txt pdf etc.).
How can I do that?
There is an option "custom" ... but haven't found how it works.
Thanks in advance
Re: Newby question: filter on file type
Post by michel038 »
if that is the primary purpose of your work, maybe you should use a keyword ?
-select all pdf files , add "documents"
-select all txt files , add "documents" etc ...
Other way, for a new feature in xnviewmp, the job is almost done in "settings, file list, custom filter ..."
What you're asking for is a customization of the first column and the ability tu use it in a filter ?
nji9
Post by nji9 »
Using a keyword for filtering...
was an idea that came into my mind too.
But it doesn't seem a good idea,
as these are two different things: filtering - labeling.
Oh, now I understand what this "custom" in the filter dialog
stands for!
Yes, I could do that there.
But only for ONE class (And without name: "custom").
Say (doc, docx, pdf, odf, odt, ...) etc. for documents.
Maybe worth a suggestion to do it better?
(Define own filters)
