... without any comment.
@ Win7-64.
Save as ... heic ... does nothing
nji9
nji9
Re: Save as ... heic ... does nothing
Same after copying the plugin viewtopic.php?f=82&t=36661
Although it already seems a bug to me if MP seem to save but doesn't do it without any message.
HEIC output is only available if you have the Windows 10 store plugin (so not on Win7)
nji9
OK ... but the points are:
- the menu entry of it IS available
(although it is of no use anywhere as in Win10) and moreover
- after choosing it there is no message at all.
Maybe to change that so there will be no more questions like this?
