Clone custom layout
neher
Clone custom layout
Post by neher »
Dear Forum,
Some while ago set the Browser layout on the -more powerful- desktop computer just the way it suits my workflow. Saved it as Layout A.
Now I'd like to have the same layout on a second -less powerful notebook- computer: searched for various combinations of "clone / copy / custom / browser / layout, in help, this forum and via google : somehow the only answer is that one can save the layout : had already noticed ...
My question to forum members is : "how can I clone that 'perfect' layout to the second computer, please?"
Spoiler : picking the 'Free' layout option shows elements of the layout I'd want, but not all elements can be moved to where I want them.
And in case you wonder what's so special : divide the screen in two halves, on the right hand side the Preview occupies the bottom two-thirds, and Info the top one-third ; on the left hand side place side by side Folders, at one-third the width of that half, and Thumbnails occupying two-thirds of that side.
Also changed the menu bar icons - icons were added, removed, or moved along : would seem easiest to copy (part of) an .ini file - on the assumption that such exists on my computer? If not, then what?
Looking forward, met vriendelijke groet (Dutch for 'with friendly greeting'),
Hans
Re: Clone custom layout
you can copy the file, saved as layout?.dat in the config folder
neher
Post by neher »
Dear Pierre,
Thank you for the reply.
For those forum visitors who, like me, don't really know their way around the Win10 folder hierarchy: the XnViewMP config folder can be found at C:\Users\[username]\AppData\Roaming\XnViewMP
Met vriendelijke groet,
Hans
