Hi there,
Categories window. When I mouseover a category, I get a Tooltip: "Click on Checkbox..." Currently the tooltip stays on for too long, covering a significant portion of the tree.
I'd like an option in Settings to either switch this off, or show the actual Category name instead. I'm OK if there is also an option to show what it currently shows. It would also be a good solution for me if the tooltip would disappear at once when I move the mouse.
In a several level deep Categories Tree, with long Categories name it is possible that the last characters or words of the category does not fit on the screen. In this case it would be useful if the Tooltip would show the Category.
BR,
Tango
Suggestion: Tooltip should show Category name
unqltango
orbspider
Re: Suggestion: Tooltip should show Category name
+1 for an option to turn off this tooltip. It's unnecessary for veteran users.
Build Debian http://dquinton.github.io/debian-install/
