First of all I want to say XnView is a great software. Congratulations to Pierre.
My suggestion is about rating images and browsing.
When in Viewer mode if you rate an image it will not appear on the image thumbnail in browser mode. I think it was a great idea that if you rate an image in Viewer mode it should automatically appear in the thumbnail in browser mode.
The second one is if you browse images in Viewer mode they also should follow the sequence in browser mode. For example if you go from image 1 to image 2 in Viewer mode you should be in the thumbnail of image 2 when you return to browser mode. What happens now is if you go from image 1 to image 2 in Viewer mode and you return to browser mode you will still be in the thumbnail of image 1.
Thanks.
Rating
Re: Rating
Thanksjramada wrote: Mon May 25, 2020 11:26 pm First of all I want to say XnView is a great software. Congratulations to Pierre.
?? you can't rate in viewer mode, are you talking about XnView MP?When in Viewer mode if you rate an image it will not appear on the image thumbnail in browser mode. I think it was a great idea that if you rate an image in Viewer mode it should automatically appear in the thumbnail in browser mode.
do you have options>Browser>synchronize browser selection?The second one is if you browse images in Viewer mode they also should follow the sequence in browser mode. For example if you go from image 1 to image 2 in Viewer mode you should be in the thumbnail of image 2 when you return to browser mode. What happens now is if you go from image 1 to image 2 in Viewer mode and you return to browser mode you will still be in the thumbnail of image 1.
jramada
Re: Rating
Yes I`m talking about XnView MP. I can rate an image in viewr mode. However what happens is: rate an image in viewer mode, then switch to browser mode and you will not see any rating in the thumbnail. However if go out from that folder to another one and then come back to that same folder, the rating appears in the thumbnail. It`s something like doing a refresh. May be I´m doing something wrong and may be you can help.
This one you helped me solving the issue. I went to preferences>Interface>Interface and ticked synchronize browser when view is closed.
Once again great software.
Thank you Pierre
Thank you Pierre
