How can one rotate an image by any angle?
Elk
How can one rotate an image by any angle, e.g. an angle of 10° / degrees or 5° or 15° (instead only by 90°, 180°, etc.)?
Re: How can one rotate an image by any angle?
In the viewer Image > Rotate > Rotate... provides a means of rotating by any angle...
Elk
Great, how can I show the menu or item "Image" in the viewer?
Image on the viewer menu bar...
Elk
Oh there! Thank you!
Elk
Sorry, cannot find that option anymore. Where is it? Do you have a screenshot?
cday wrote: Tue May 26, 2020 5:45 am In the viewer Image > Rotate > Rotate... provides a means of rotating by any angle...
It's still there in 0.98.1:Elk wrote: Mon Feb 08, 2021 12:37 pm Sorry, cannot find that option anymore. Where is it? Do you have a screenshot?
Elk
Thank you very much!
Sorry, but where is it here(?):
You are in the browser, not the viewer...cday wrote: Tue May 26, 2020 5:45 am In the viewer Image > Rotate > Rotate... provides a means of rotating by any angle...
Elk
And how do I get to the viewer and to that menu?
Open any image, double-click on a thumbnail, or use File > Open...
Elk
Ah, now I see, one has to show the menu bar first in that Viewer, that's why I didn't find it. The Viewer:
Many thanks!
Is there a method to show (temporarily) that menu bar or the rotate option in the Viewer?
Many thanks!
It looks as if you are in fullscreen, you would need to exit that using F11 or Escape.Elk wrote: Mon Feb 08, 2021 1:36 pm Ah, now I see, one has to show the menu bar first in that Viewer, that's why I didn't find it. The Viewer:
In the viewer display of the toolbar requires View > Toolbar to be checked, the default setting so it should normally be displayed.
Elk
Ah, yes, fullscreen.
Great! All working now. Many thanks!
