Saving in jp2000, bug
nji9
Post by nji9 »
If saving a file in jp2000 format choosing
option quality 80% is about the same as lossless option.
Saving with IrfanView with Q=80% produces a file with only a third size.
==> Bug with saving option.
Re: Saving in jp2000, bug
i've tried, the output file is not the same. And i don't use same jpeg2000 codec as I****
nji9
Post by nji9 »
Are saying that everything is OK then?
yes, you can't compare quality between 2 different coders
