[Solved] Crop tool not operating as expected
dev/null
Post by dev/null »
I would like to ask how the crop tool should work
Now when I choose the crop tool:
  • I can't select the crop area with the mouse selection
  • I can't move or change the crop area (that i select from list) with the mouse
Is this the expected behavior?
At first glance, it looks really strange and not intuitive
My env:
Win 10 v 1909
XnViewMP Version 0.96.2 64bits
Re: Using the crop tool
dev/null wrote: Thu May 28, 2020 6:08 amNow when I choose the crop tool:
With Free selected in the drop-down on the left, you can't make and change a mouse selection in the normal way??
Or you are saying that when a preset value is selected, the selection can only be moved or rotated, but the dimensions can't be altered?
dev/null
Post by dev/null »
cday wrote: Thu May 28, 2020 6:25 am With Free selected in the drop-down on the left, you can't make and change a mouse selection in the normal way??
Yes, i can't
cday wrote: Thu May 28, 2020 6:25 am Or you are saying that when a preset value is selected, the selection can only be moved or rotated, but the dimensions can't be altered?
I can move or change, but not with the mouse. I can do this only by changing the parameter next to list
I show you screen GIF how the situation looks like:
Re: Crop tool not operating as expected
Crop tool operation is normal for me using XnView MP 0.96.2 on Linux.
Possibly an issue related to your exact sequence, or maybe related to particular mouse options in Tools > Settings... > Interface -- Mouse tab ??
If you are able to identify steps to reproduce that would help Pierre...
dev/null
Post by dev/null »
cday wrote: Thu May 28, 2020 7:31 am maybe related to particular mouse options in Tools > Settings... > Interface -- Mouse tab ??
Yes Yes Yes! This is it!
I couldn't use it because I have different settings on the Mouse tab
Now I can use the crop tool with the mouse when the Ctrl key is pressed
Thank you for your help
We can close this issue
