Delete categories : small improvement request
Gwenael Q.
Post by Gwenael Q. »
It is currently possible to select more than one category in the categories pane and apply to them some commands with a right-click, but "delete" is not available with multiple selection.
Expected behavior : user should be able to erase more than one category at once.
Please note that there is a workaround : move multiple categories into a temporary parent category then delete the latter at the end.
Thank you for listening
Gwenael Q.
Re: Delete categories : small improvement request
Requested feature would still be useful.
Thanks for the good job
Gwenael Q.
+1
1.5.0
