0.96.2 - Issue moving a category by drag&drop - UI misleading
Gwenael Q.
Post by Gwenael Q. »
When user drags a category in the categories pane, a black rectangle or black line appears around/above/under the hovered category (especially nested ones).
Rectangle is expected to mean "drop into" = "dropped category will be subcategory" and line "drop next to" = "dropped category will be sister category".
Issue : category dropped when UI displays a black line ends as a subcategory of the hovered one (should be a sister one). Black line and black rectangle seems to behave quite the same manner and they shouldn't.
0.96.2 x64 on windows 8.1 x64
Thank you for listening
Re: 0.96.2 - Issue moving a category by drag&drop - UI misleading
you means when you drag&drop a file on categories pane?
Gwenael Q.
Hello Pierre,
No, I mean drag&drop of a category on another, inside the categories pane : place mouse pointer on a category, press and hold left mouse button then move mouse pointer over other categories.
Best regards
right, in 'categories' pane, you should not have the line to insert a category
I can't remove it, it's in QT API
