I tested xnviewmp on a windows 10 64bit (1909) system with network drives. Since the latest release of xnviewmp I could not see thumbnails in browser window of network drives. Local drives and folders are no problem. I can open and view files from network drives, so it should not be a problem of network access or missing filesystem rights. In the past I did not get this error with xnviewmp 0.95 or 0.96.
Maybe something has changed in xnviewmp or a problem with windows 10 (version 1909)?
0.96.2 - browsing window does not show thumbnails on network drives
masterjp
Re: 0.96.2 - browsing window does not show thumbnails on network drives
could you try with 0.95?
masterjp
Yes, I can test it with an older version, but I do not have xnviewmp 0.95 (portable/installer) anymore.
I could not find a website with older versions of the software.
Hidden: Old versionsmasterjp wrote: Sun Jun 07, 2020 8:02 pm I could not find a website with older versions of the software.
Scroll down or search...
masterjp
Today I tested XnViewMP 0.95 64bit and both network drives work fine.
With XnViewMP 0.96 64 bit I only can see the files and folders of one network drive.
Maybe it is a problem of the old windows 10 version 1803 on this system?
All security updates are installed, but no feature updates.
no rights problem?masterjp wrote: Tue Jun 09, 2020 9:41 am Today I tested XnViewMP 0.95 64bit and both network drives work fine.
masterjp
I have read and right permission to both network drives, but I am not the administrator.
Maybe something else in the system is not correctly.
But XnViewMP 0.95 works perfect.
Did you use newer qt libraries or something else to compile XnViewMP 0.96.x?
i've no problem to see thumbnails on network drives. You have this problem for ALL?
masterjp
Yes, I can not see any thumbnails of the picture files on one of my network drive.
I have the Treeview of the directories on the left side in browser window.
It is possible to navigate through the left folder structure, but nothing happend.
I do not see any thumbnail. In XnViewMP 0.95 it works without problems.
If I can click and open the directories in the treeview, I will have the permission to access to folders.
I tested other programs (IrfanVIew and Thumbnail mode) and there are no problems.
you have only the icon of files?masterjp wrote: Tue Jun 30, 2020 6:13 pm Yes, I can not see any thumbnails of the picture files on one of my network drive.
