Embedded comment, can't be found
Marcus
Post by Marcus »
In XnviewMP, I create an embedded comment (Crtl-D) for a jpg file and write "text"
If a select the file, I can see in the Info Panel, Properties, Embedded Comment: "text"
Then I try to search for it: Ctrl-F, Add>>, Embedded Comment, contains or is "text", and it shows no results
What am I doing wrong? Thanks
XnView MP Windows
Version 0.96.2 32bits (May 5 2020)
Marcus
Re: Embedded comment, can't be found
'use catalog' is checked?
Marcus
Post by Marcus »
Yes, checked
Case sensitive, unchecked
"Files" search field left blank, also tried "*.jpg"
Search results window shows it looked in the rigth folder (there are only two files in it)
XnviewMP closed and reopened, no change
I updated catalog from files, no change
Thanks for your answer
Marcus
Marcus
Post by Marcus »
Ok, thanks to you
Great software, congratulations
Marcus
This problem is supposed to be fixed in XnView MP 0.96.3. Please check and confirm the bug fix here.
