When removing orphaned items from catalog
the number of items (in brackets) is not updated.
You have to close and reopen MP.
Categories, number of items not updated in pane
nji9
Re: Categories, number of items not updated in pane
when using 'remove from category'?
nji9
I do not understand your question.
What or where is 'remove from category'?
It's quite simple isn't it:
I update the catalog db by "optimizing" it.
Formerly deleted items are (at last!!!) removed.
But it doesn't show in the numbers in the category pane at once.
Bug obviously.
Bug obviously.
you means Settings>Catalog>Delete?
nji9
No.
I do mean Setting - Catalog - Optimize.
This problem is supposed to be fixed in XnView MP 0.96.3. Please check and confirm the bug fix here.
