Moving and zooming while Adjusting
When adjusting contrast, saturation and other parameters of the image using the "Adjust" dialog (Image > Adjust > Brightnesss/Contrast/Gamma/Balance), the user is "locked" in the dialog. Instead, the user should be able to some actions on the image like Zooming and moving. This is important to find out about the result before being applied and standard in many other graphic programs.
The same applies for other dialogs (Rotate, Effects, ...).
Re: Moving and zooming while Adjusting
helmut wrote:When adjusting contrast, saturation and other parameters of the image using the "Adjust" dialog (Image > Adjust > Brightnesss/Contrast/Gamma/Balance), the user is "locked" in the dialog. Instead, the user should be able to some actions on the image like Zooming and moving. This is important to find out about the result before being applied and standard in many other graphic programs.
Yes i agree, but currently not possible
xnview wrote:
helmut wrote:... This is important to find out about the result before being applied and standard in many other graphic programs.
Yes, I have noticed that.
