"update catalog from files" no update the xmp and iptc keywords for category
How to reproduce it.
Use MS paint create new jpg file and save
modify the category in XnViewMP
Use MS paint create new jpg file and replace the old one
"update catalog from files" will not update the catalog.
XnView MP Windows
Version 0.96.2 64bits (May 5 2020)
Libformat version 7.40
"update catalog from files" not working after edit xmp from external
hlhp
Re: "update catalog from files" not working after edit xmp from external
what are your settings>Metadata?
hlhp
It is working now! I think I did something wrong with MS paint.
Just incase, this is my settings.
