Hi, I would like to add some color to my scrollbars. I see posts about a CSS file, so I guess that it is possible to tweak the interface with a stylesheet, but I don't know where the css should go, or how to point xnview to the stylesheet, or which tags to use. Where can I find that information?
tnx!
color the scrollbars
Re: color the scrollbars
you can use it View>Theme
sdfsdfsd
Hi Pierre,
tnx for replying. I'm still confused. I tried your solution menu > view > theme, but only "dark theme" offers me a qss file (which is the qss file in /opt/XnView/UI/). I can change the color of the scrollbars there, but I don't want a dark theme. I want the default theme with colored scrollbars, but I can't find the qss for default style.
I also tried entering only a value for the scrollbars in the qss file, hoping that XnView would then use default theme, but with my colored scrollbars, but that didn't work. The qss file needs to be complete, if there is only one element missing, the entire file is ignored.
So where can I find the qss file for default theme?
Tnx!
using XnView MP Linux, Version 0.96.2 64bits (May 6 2020) on Linux Mint 18.3 mate
Tnx!
you can remove all other css style
sdfsdfsd
Tnx Pierre, I've got it now!
