"Open in File Explorer" Not Working in MX Linux
I used "Open in File Explorer" frequently in Linux Mint 18.1 and it worked every time. But I just moved to MX Linux 19.2 and it is not working. Nothing happens, the OS file explorer doesn't open. Is there a config file I can edit to make it work? It's a feature I use often.
Re: "Open in File Explorer" Not Working in MX Linux
Here's the output in the terminal when trying "Open in File Explorer":
** (process:12146): WARNING **: 13:57:32.455: Failed to load shared library 'libgdk-3.so.0' referenced by the typelib: /lib/x86_64-linux-gnu/libcairo.so.2: undefined symbol: FT_Get_Var_Design_Coordinates
Traceback (most recent call last):
File "/usr/bin/catfish", line 27, in <module>
from gi.repository import Gtk
File "<frozen importlib._bootstrap>", line 983, in _find_and_load
File "<frozen importlib._bootstrap>", line 967, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 668, in _load_unlocked
File "<frozen importlib._bootstrap>", line 638, in _load_backward_compatible
File "/usr/lib/python3/dist-packages/gi/importer.py", line 145, in load_module
importlib.import_module('gi.repository.' + dep.split("-")[0])
File "/usr/lib/python3.7/importlib/__init__.py", line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1006, in _gcd_import
File "/usr/lib/python3/dist-packages/gi/importer.py", line 146, in load_module
dynamic_module = load_overrides(introspection_module)
File "/usr/lib/python3/dist-packages/gi/overrides/__init__.py", line 125, in load_overrides
override_mod = importlib.import_module(override_package_name)
File "/usr/lib/python3/dist-packages/gi/overrides/Gdk.py", line 81, in <module>
Color = override(Color)
File "/usr/lib/python3/dist-packages/gi/overrides/__init__.py", line 202, in override
assert g_type != TYPE_NONE
AssertionError
AssertionError
