I had the following problem:
$ ./nconvert
ld.so.1: ./nconvert: fatal: relocation error: file /afs/b83503104/lib/libformat.so: symbol __sqrtf: referenced symbol not found
Killed
After put nconvert and libformat.so.4.16 in the right places like this:
cp lib/libformat.so.${LIBVERSION} $BASEDIR/lib
rm -f $BASEDIR/lib/libformat.so
chmod 755 $BASEDIR/lib/libformat.so.${LIBVERSION}
ln -s $BASEDIR/lib/libformat.so.${LIBVERSION} BASEDIR/lib/libformat.so
Could anyone point out what I was missing?
Thanks,
David
Problem installing NConvert on Solaris
Re: Problem installing Nconvert on Solaris
Which distribution do you have? Which version?b83503104 wrote:...
PaulHamacher
$ LD_LIBRARY_PATH=/home/work/XnView/lib
$ export LD_LIBRARY_PATH
$ bin/nconvert
ld.so.1: bin/nconvert: fatal: relocation error: file /home/work/XnView/lib/libfo
$ uname -a
SunOS omega 5.8 Generic_108528-15 sun4u sparc SUNW,Sun-Fire-880
From ReadMe.txt : Nconvert v4.16
What is missing?
Paul
$ bin/nconvert
$ uname -a
What is missing?
Paul
Strange some users have this problem. I don't know why.PaulHamacher wrote:$ LD_LIBRARY_PATH=/home/work/XnView/lib
$ bin/nconvert
$ uname -a
What is missing?
Could you send me an email, i'll send you the previous version.
ben
has anybody gotten to the bottom of this?
I'm having the same problem with a different application.
Can't figure out how to debug it.
When I try to use dbx where after the crash, it says the application is not longer active, and it doesn't give any info on line numbers or anything.
Any body have any ideas?
Thanks
-Ben
Thanks
-Ben
