ESC from fullscreen creates a new window
kentavv
Post by kentavv »
With Windows 10 and XnView MP 0.96.2, starting in the thumbnail view, I double click an image to see fullscreen. Then I press Esc to return to the thumbnail view. Sometimes pressing Esc creates a new thumbnail window. The follow video shows this. While I'm showing the problem with a Ora file, which consistently shows this problem, I also see it with PNG files, but not always.
https://youtu.be/b2XumZYHv5A
Re: ESC from fullscreen creates a new window
i can't reproduce, what is ora files?
kentavv
Post by kentavv »
Hi. The video shows an ora file, which are openraster files, but I see the new window created with png files too. The extra window creation is disorienting at times. It does not happen every time, but enough that I'll have several instances of XnView running after a while. Let me know if there is anything else I can do to help. Thank you
with lastest version too?
