Are Open Raster (.ora) files supported by XnView MP 0.96.2? The .ora files exported from Gimp only load as a blank page in XnView MP.
I tried installing the plugin from viewtopic.php?t=11715 only to find that those are for XnView Classic. So no surprise that the plugin is not listed in XnView MP.
Is Open Raster supported?
Thank you
Is OpenRaster supported by XnView MP?
Re: Is OpenRaster supported by XnView MP?
this plugin is for 32bits version, i'll try to build it for 64bits
