"Tag current" hot key customization
fedelin
Post by fedelin »
Changing "Tag current" hot key from "Crtl+T" to "G" (for instance) in Settings/Interface/Shortcuts
New hot key works fine in the explorer but the changed is not reflected into the full screen view nor on the edit view (i.e. "Ctrl+T" are stil the shortcut to Tag the photo)
Did not test if it's a general shortcutcustomization issue or only related to "Tag current"
Best Regards,
Franz
Quand ça marche on apprend rien...
luppa
Re: "Tag current" hot key customization
Post by luppa »
While testing my own problems with tagging images in different modes I tried changing the keyboard shortcut for tagging, and I was succesful, so I can't replicate this bug. You did notice that there are different shortcuts for Browser mode and Viewer mode? (dropdown menu on the top left of the Shortcuts tab)
fedelin
Post by fedelin »
Hi Luppa,
No I did not. Thanks for the tip !
Tested ok
This post should be moved to the "stupid question" categorie :?
Franz
