XnViewMP 96.3 not loading in Linux Mint 20 Cinnamon
DanPF
Post by DanPF »
I have seen several reports in various forums (but strangely not here) that XnVMP not starting in the recent release of Linux Min 20. I cant verify this as I dare not upgrade if this software wont work, as it is essential to my project. Has anyone here been successful in upgrading and loading XnVMP in Mint 20 Cinnamon?
EDIT:
I found someone helpful at least put up an error message - Of course this might be a Mint issue and not XnVmp
"Also , running XnViewMP (the most recent version 0.69.2 downloaded from the author’s site as a deb) fails with:
qt5ct: using qt5ct plugin
Segmentation fault (core dumped)"
Thanks Dan
DanPF
Re: XnViewMP 96.3 not loading in Linux Mint 20 Cinnamon
Post by DanPF »
I just managed to try this in the Live Usb environment. Install from the .deb goes just fine but it will not launch giving me the same error message as above. I would really appreciate some help here as Ver 20 of Mint has something that I would like, so it would be a pity if I could not upgrade.
DanPF
Post by DanPF »
I found in the new repos there is a Flatpack version (93.1) which does work. This indicates to me that something in the later versions has caused this issue rather than LM20?
DanPF
Post by DanPF »
Last post - sorry for the drip feed of info,
I have just found that the AppImage file does run in LM20 Cinnamon. So I am confused what the AppImage contains that the LM20 system does not provide natively?
if you use export QT_DEBUG_PLUGINS=1 in a terminal, what do you see when executing XnView?
DanPF
Post by DanPF »
xnview wrote: Tue Jun 30, 2020 2:55 pm if you use export QT_DEBUG_PLUGINS=1 in a terminal, what do you see when executing XnView?
I loaded the 64bit deb file from your web Home page in a USB Live session.
opened a terminal and typed in QT_DEBUG_PLUGINS=1 the result was the same as others have reported
I hope that helps you.
Dan
DanPF
Post by DanPF »
xnview wrote: Wed Jul 01, 2020 4:09 pm
Oops My Bad sorry,
here is the output
QFactoryLoader::QFactoryLoader() checking directory path "/opt/XnView/lib/platforms" ...
QFactoryLoader::QFactoryLoader() looking at "/opt/XnView/lib/platforms/libqlinuxfb.so"
Found metadata in lib /opt/XnView/lib/platforms/libqlinuxfb.so, metadata=
    "IID": "org.qt-project.Qt.QPA.QPlatformIntegrationFactoryInterface.5.3",
    "MetaData": {
        "Keys": [
            "linuxfb"
    "archreq": 0,
    "className": "QLinuxFbIntegrationPlugin",
    "debug": false,
    "version": 330752
Got keys from plugin meta data ("linuxfb")
QFactoryLoader::QFactoryLoader() looking at "/opt/XnView/lib/platforms/libqminimal.so"
Found metadata in lib /opt/XnView/lib/platforms/libqminimal.so, metadata=
    "MetaData": {
        "Keys": [
            "minimal"
    "archreq": 0,
    "className": "QMinimalIntegrationPlugin",
    "debug": false,
    "version": 330752
Got keys from plugin meta data ("minimal")
QFactoryLoader::QFactoryLoader() looking at "/opt/XnView/lib/platforms/libqminimalegl.so"
Found metadata in lib /opt/XnView/lib/platforms/libqminimalegl.so, metadata=
    "MetaData": {
        "Keys": [
            "minimalegl"
    "archreq": 0,
    "className": "QMinimalEglIntegrationPlugin",
    "debug": false,
    "version": 330752
Got keys from plugin meta data ("minimalegl")
QFactoryLoader::QFactoryLoader() looking at "/opt/XnView/lib/platforms/libqoffscreen.so"
Found metadata in lib /opt/XnView/lib/platforms/libqoffscreen.so, metadata=
    "MetaData": {
        "Keys": [
            "offscreen"
    "archreq": 0,
    "className": "QOffscreenIntegrationPlugin",
    "debug": false,
    "version": 330752
Got keys from plugin meta data ("offscreen")
QFactoryLoader::QFactoryLoader() looking at "/opt/XnView/lib/platforms/libqvnc.so"
Found metadata in lib /opt/XnView/lib/platforms/libqvnc.so, metadata=
    "MetaData": {
        "Keys": [
            "vnc"
    "archreq": 0,
    "className": "QVncIntegrationPlugin",
    "debug": false,
    "version": 330752
Got keys from plugin meta data ("vnc")
QFactoryLoader::QFactoryLoader() looking at "/opt/XnView/lib/platforms/libqwayland-egl.so"
Found metadata in lib /opt/XnView/lib/platforms/libqwayland-egl.so, metadata=
    "MetaData": {
        "Keys": [
            "wayland-egl"
    "archreq": 0,
    "className": "QWaylandEglPlatformIntegrationPlugin",
    "debug": false,
    "version": 330752
Got keys from plugin meta data ("wayland-egl")
QFactoryLoader::QFactoryLoader() looking at "/opt/XnView/lib/platforms/libqwayland-generic.so"
Found metadata in lib /opt/XnView/lib/platforms/libqwayland-generic.so, metadata=
    "MetaData": {
        "Keys": [
            "wayland"
    "archreq": 0,
    "className": "QWaylandIntegrationPlugin",
    "debug": false,
    "version": 330752
Got keys from plugin meta data ("wayland")
QFactoryLoader::QFactoryLoader() looking at "/opt/XnView/lib/platforms/libqwayland-xcomposite-egl.so"
Found metadata in lib /opt/XnView/lib/platforms/libqwayland-xcomposite-egl.so, metadata=
    "MetaData": {
        "Keys": [
            "wayland-xcomposite-egl"
    "archreq": 0,
    "className": "QWaylandXCompositeEglPlatformIntegrationPlugin",
    "debug": false,
    "version": 330752
Got keys from plugin meta data ("wayland-xcomposite-egl")
QFactoryLoader::QFactoryLoader() looking at "/opt/XnView/lib/platforms/libqwayland-xcomposite-glx.so"
Found metadata in lib /opt/XnView/lib/platforms/libqwayland-xcomposite-glx.so, metadata=
    "MetaData": {
        "Keys": [
            "wayland-xcomposite-glx"
    "archreq": 0,
    "className": "QWaylandXCompositeGlxPlatformIntegrationPlugin",
    "debug": false,
    "version": 330752
Got keys from plugin meta data ("wayland-xcomposite-glx")
QFactoryLoader::QFactoryLoader() looking at "/opt/XnView/lib/platforms/libqxcb.so"
Found metadata in lib /opt/XnView/lib/platforms/libqxcb.so, metadata=
    "MetaData": {
        "Keys": [
            "xcb"
    "archreq": 0,
    "className": "QXcbIntegrationPlugin",
    "debug": false,
    "version": 330752
Got keys from plugin meta data ("xcb")
QFactoryLoader::QFactoryLoader() checking directory path "/opt/XnView/platforms" ...
loaded library "/opt/XnView/lib/platforms/libqxcb.so"
loaded library "Xcursor"
QFactoryLoader::QFactoryLoader() checking directory path "/opt/XnView/lib/platformthemes" ...
QFactoryLoader::QFactoryLoader() looking at "/opt/XnView/lib/platformthemes/libqgtk2.so"
Found metadata in lib /opt/XnView/lib/platformthemes/libqgtk2.so, metadata=
    "IID": "org.qt-project.Qt.QPA.QPlatformThemeFactoryInterface.5.1",
    "MetaData": {
        "Keys": [
            "gtk2"
    "archreq": 0,
    "className": "QGtk2ThemePlugin",
    "debug": false,
    "version": 330752
Got keys from plugin meta data ("gtk2")
QFactoryLoader::QFactoryLoader() looking at "/opt/XnView/lib/platformthemes/libqgtk3.so"
Found metadata in lib /opt/XnView/lib/platformthemes/libqgtk3.so, metadata=
    "MetaData": {
        "Keys": [
            "gtk3"
    "archreq": 0,
    "className": "QGtk3ThemePlugin",
    "debug": false,
    "version": 330752
Got keys from plugin meta data ("gtk3")
QFactoryLoader::QFactoryLoader() looking at "/opt/XnView/lib/platformthemes/libqt5ct.so"
Found metadata in lib /opt/XnView/lib/platformthemes/libqt5ct.so, metadata=
    "MetaData": {
        "Keys": [
            "qt5ct"
    "archreq": 0,
    "className": "Qt5CTPlatformThemePlugin",
    "debug": false,
    "version": 330752
Got keys from plugin meta data ("qt5ct")
QFactoryLoader::QFactoryLoader() looking at "/opt/XnView/lib/platformthemes/libqxdgdesktopportal.so"
Found metadata in lib /opt/XnView/lib/platformthemes/libqxdgdesktopportal.so, metadata=
    "MetaData": {
        "Keys": [
            "xdgdesktopportal",
            "flatpak",
            "snap"
    "archreq": 0,
    "className": "QXdgDesktopPortalThemePlugin",
    "debug": false,
    "version": 330752
Got keys from plugin meta data ("xdgdesktopportal", "flatpak", "snap")
QFactoryLoader::QFactoryLoader() checking directory path "/opt/XnView/platformthemes" ...
loaded library "/opt/XnView/lib/platformthemes/libqt5ct.so"
QFactoryLoader::QFactoryLoader() checking directory path "/opt/XnView/lib/styles" ...
QFactoryLoader::QFactoryLoader() looking at "/opt/XnView/lib/styles/libqgtk2style.so"
Found metadata in lib /opt/XnView/lib/styles/libqgtk2style.so, metadata=
    "IID": "org.qt-project.Qt.QStyleFactoryInterface",
    "MetaData": {
        "Keys": [
            "gtk2"
    "archreq": 0,
    "className": "QGtk2StylePlugin",
    "debug": false,
    "version": 330752
QFactoryLoader::QFactoryLoader() looking at "/opt/XnView/lib/styles/libqt5ct-style.so"
Found metadata in lib /opt/XnView/lib/styles/libqt5ct-style.so, metadata=
    "MetaData": {
        "Keys": [
            "qt5ct-style"
    "archreq": 0,
    "className": "Qt5CTStylePlugin",
    "debug": false,
    "version": 330752
Got keys from plugin meta data ("qt5ct-style")
QFactoryLoader::QFactoryLoader() checking directory path "/opt/XnView/styles" ...
QFactoryLoader::QFactoryLoader() checking directory path "/opt/XnView/lib/platforminputcontexts" ...
QFactoryLoader::QFactoryLoader() checking directory path "/opt/XnView/platforminputcontexts" ...
loaded library "/opt/XnView/lib/styles/libqt5ct-style.so"
Cannot load library /opt/XnView/lib/styles/libqgtk2style.so: (/usr/lib/x86_64-linux-gnu/libcairo.so.2: undefined symbol: FT_Get_Var_Design_Coordinates)
QLibraryPrivate::loadPlugin failed on "/opt/XnView/lib/styles/libqgtk2style.so" : "Cannot load library /opt/XnView/lib/styles/libqgtk2style.so: (/usr/lib/x86_64-linux-gnu/libcairo.so.2: undefined symbol: FT_Get_Var_Design_Coordinates)"
Any help?
try to remove libqt5ct-style.so or libqgtk2style.so
DanPF
Post by DanPF »
xnview wrote: Thu Jul 02, 2020 12:21 pm try to remove libqt5ct-style.so or libqgtk2style.so
Ok, Done, again only in the ISO USB live environment:
I deleted libqgtk2style.so from
Running the program from the terminal It loads fine now. I was not able to test for a dark theme or view anything due to time constraints - but a brief look showed all ok. The terminal response was
mint@mint:~$ xnview
==> 1.000000  91.793814  96.000000  (0)
XNVIEW restoreGeometry before : 640 480
XNVIEW restoreGeometry after : 850 620
w.init
XNVIEW SIZE 850 620
########### BrowserWindow :: BrowserWindow
libpng warning: iCCP: known incorrect sRGB profile
MENU install : 0x2eeda50
ThumbLoaderThread :: stop()
########### BrowserWindow :: ok create (640 480)
BrowserWindow :: changeVisibility()
########### BrowserWindow :: restoreState (850 620)
BrowserWindow :: restoreState => 850 620
                              => 588 419
BrowserWindow :: restoreState ok => 588 419
XNVIEW SIZE ok 850 620
w.start
### BrowserWindow :: onStart go
#### onFavoriteDockVisible (1)
 BookmarkNode::BookmarkNode : 0x31baf70
#### onCategoryFilterDockVisible (1)
CREATE DB
CREATE DB OK
#### onCategoryDockVisible (1)
########### BrowserWindow :: restoreState (850 588)
BrowserWindow :: restoreState => 850 588
                              => 588 239
BrowserWindow :: restoreState ok => 588 239
BrowserWindow :: onStart 2
setPathname </home/mint/>
### ThumbLoaderThread :: setFileList(0)
### ThumbLoaderThread :: setFileList() wait
######ThumbLoaderThread :: run : 304f710
######ThumbLoaderThread :: forever : 304f710
 ** start condition wait
### ThumbLoaderThread :: setFileList() after wait
 ** start condition wake one 2
######ThumbLoaderThread :: forever 2 : 304f710
CHECK <0>
## OPEN FOLDER
  ## OPEN DB FOLDER ok  0
  ## UPDATE DB FOLDER ok  0
  ## OPEN FOLDER ok  0
## updateLabel  0
## updateLabels ok  0
######### CategoryModel :: checkAndSave()
SORT the list...
STD::SORT... OK
SORT the list... 0
SORT the list... 0
BitmapLoadThread :: stop()
QObject::disconnect: No such signal CategoryView::selectionChanged(const DBFilterModel::DBFileList&)
QObject::connect: No such signal CategoryView::selectionChanged(const DBFilterModel::DBFileList&)
Create children /home/mint/
MyDirModelThread :: run
## OPEN FOLDER done  2
### ThumbLoaderThread :: setFileList(9)
CHECK <8>
### START 9
######ThumbLoaderThread :: start : 8     -1 -1
### BrowserWindow :: finish
 CHECK : <ubiquity.desktop>
LOAD BITMAP </home/mint/Desktop/ubiquity.desktop>
my_error_exit...<Not a JPEG file: starts with 0x5b 0x44>
GFF :: LoadThumbnail : 2
sizeHints : 128
sizeHints : 128
### ThumbLoaderThread :: setFirstItemToLoad
 ** start condition wake one 3
### ThumbLoaderThread :: setFirstItemToLoad ok
CHECK <0>
sizeHints : 128
sizeHints : 128
CHECK <0>
SAVE : 1920 984
BrowserWindow :: saveState => 1920 984
                           => 1658 635
######ThumbLoaderThread :: run : 304f710 OK
QMutex: destroying locked mutex
 AFTER WAIT
 BookmarkNode::~BookmarkNode : 0x31baf70
ben_sa2000
Post by ben_sa2000 »
DanPF wrote: Sat Jun 27, 2020 10:56 pm I found in the new repos there is a Flatpack version (93.1) which does work. This indicates to me that something in the later versions has caused this issue rather than LM20?
Some old version of libfreetype started getting shipped in 0.95.
libfreetype depends on libfontconfig, but since libfontconfig is not provided in the archive and the system , we need to remove this old libfreetype version so that Xnview uses the system newer libfreetype.
sudo rm /opt/lib/XnView/libfreetype.so
Tip from AUR Archlinux
Working perfectly
