Tabs vs Floating Windows
Jeepwhisperer
Post by Jeepwhisperer »
I just changed from an old copy of xnview to MP, and now I have tabs instead of windows when I open files... don't want tabs... I haven't yet found a way to reclaim this 'classic' function. Can I?
Jeepwhisperer
Re: Tabs vs Floating Windows
...searching the forum I find an indication that there may have been the option to change this feature "single view for multiple files" on the Interface menu in 2017, but it's not there now. Has it moved or been eliminated?
Jeepwhisperer
I'll take the silence as meaning "no." This is something that I would very much like to have in the final version of MP, but for now I've installed a fresh updated copy of Classic... do I need to uninstall MP or can the two coexist? Will the Windows Uninstall function do the trick? Topic for another thread maybe...
BTW, the reason I was updating was to be able to open WEBP files, something that still doesn't seem to work...
Jeepwhisperer wrote: Wed Jul 01, 2020 7:20 pm I just changed from an old copy of xnview to MP, and now I have tabs instead of windows when I open files... don't want tabs... I haven't yet found a way to reclaim this 'classic' function. Can I?
Your post surprised me because I thought that XnView Classic normally had tabs: having reluctantly booted into Windows, I can now confirm that... :wink:
Jeepwhisperer wrote: Wed Jul 01, 2020 10:40 pm ...searching the forum I find an indication that there may have been the option to change this feature "single view for multiple files" on the Interface menu in 2017, but it's not there now. Has it moved or been eliminated?
I don't know any history of that...
Jeepwhisperer wrote: Fri Jul 03, 2020 3:50 pm I'll take the silence as meaning "no." This is something that I would very much like to have in the final version of MP, but for now I've installed a fresh updated copy of Classic... do I need to uninstall MP or can the two coexist? Will the Windows Uninstall function do the trick? Topic for another thread maybe...
I see there is an option in the in the MP settings to set the maximum number of tabs = 1, you can see if that gives the result you need:
Tools > Settings > Interface -- Tabs -- Maximum of view tabs
XnView MP and XnView Classic are completely separate and can coexist, but if you use XnView MP 64-bit to open PDF and certain other file types you will need to install Ghostscript 64-bit as well as 32-bit.
