Images smaller than screen get stretched to screensize
MarlonB
Post by MarlonB »
When I view an image (smaller than the resolution of my screen) in fullscreen mode, it gets stretched to match the size of the screen.
I've changed the setting under View / Auto Image Size to "fit image to window, large only", but this doesn't have any effect.
What do I need to change to keep the images as they are?
Thanks!
Re: Images smaller than screen get stretched to screensize
and in Settings>Fullscreen - auto image size?
MarlonB
Post by MarlonB »
xnview wrote: Mon Jul 20, 2020 9:26 am and in Settings>Fullscreen - auto image size?
Thanks, as it turns out, I need to restart XnView MP to have the settings take effect. As soon as I restarted XnView MP (after changing the above setting), it worked.
