Images do not open from MS Explorer (v1.68.1)
MiAsMA
Post by MiAsMA »
I just downloaded and installed XnView 1.68.1, I associated the "most used images" to XnView but they are opened in the program's viewer instead they're opened in the Windows Pìcture and Fax Viewer (Windows XP Pro SP1). The Funny thing is that I don't have this problem in my File Manager, Total Commander 6.01.
If anyone has any idea what I can do I'd appreciate it :)
Please have a look at the post File associations on Windows XP.
MiAsMa
Thanx
Post by MiAsMa »
It was really helpful the link.
Thank you for your post :)
