opening a file shows a little window (multi-monitor)
lian
Post by lian »
Hello, it may be a multi-monitor relative problem but I cannot find any fix.
When I open a file in explorer, XnViewMP shows a little window on principal monitor (Highest resolution)
If I change the size of the window, I can open new files in same window sizes. But after rebooting my PC, the problem is still here. The last window size is not memorized.
SF, illustrations et mes BD sur mon blog: https://www.li-an.fr/
Windows 10 Home 64 bits
Re: opening a file shows a little window (multi-monitor)
Without restarting your PC, the window size is kept between session, but not after a reboot???
Where do you save the settings?
