XnViewMP is extremely good
atomicthumbs
Post by atomicthumbs »
Not a support topic, but I just wanted to say that this is one of the most useful pieces of software I know of. It belongs to a category of tools that "fits perfectly to the user's hand;" if you need to do anything to images, you can usually figure out how to do it with XnViewMP, in a way that's efficient and intuitive. It's well-designed, ergonomic, and considerate.
So, thanks for your work on this!
Re: XnViewMP is extremely good
Thanks a lot to use it!
