uninstall xnview (linux)
Questions, suggestions, and answers for XnView on all Un*x platforms (Linux, HP-UX, AIX, ...)
martin
Post by martin »
<Moderator's note: This topic has been moved>
I want to uninstall XnView, but it isn't possible. There (in Terminal) is an error mesage that XnView doesn't exist... but it exists! (I have Fedora Core 4.)
Do you have an idea? How to uninstall XnView?
Thanks,
Martin
Remi
Post by Remi »
How did you install it ?
If you install the RPM, simply :
rpm -e XnView
or
yum remove XnView
La communauté française Fedora : http://www.fedora-france.org/
Des RPM pour FC : http://remi.collet.free.fr/
martin
Post by martin »
It was installed by
rpm -Uvh XnView-static-fc4.i386.rpm
I tried uninstall XnView with
rpm -e xnview
but in Terminal was a message that xnview isn't installed...
If I type
yum remove XnView
it create a message:
yum remove xnview
Repository updates-released is listed more than once in the configuration
Repository base is listed more than once in the configuration
Setting up Remove Process
No Match for argument: xnview
No Packages marked for removal
jdautz
uninstall
Post by jdautz »
perhaps : --rebuilddb ??
Remi
Post by Remi »
rpm and yum are case sensitive.
So
rpm -e XnView
not
rpm -e xnview
martin
Post by martin »
:D Thank you!
