Image from Clipboard saves under other user credentials
EuM_Expert
Post by EuM_Expert »
I take a screenshot (into the clipboard).
Then open windows explorer - no file to see ...
I check the disk with an admin account - and there you go, the file is there.
xnViewMP saves clipboard / new files to a different user account (which is not visible to my normal user account).
Anybody had this bug as well?
How to overcome this?
Thanks EuM
Windows 10
Version 0.96.4 64bits (Jun 30 2020)
Rick
Re: Image from Clipboard saves under other user credentials
Post by Rick »
What happens when you leave the ADMIN account and go back. Is the file now visible in that account also?
It sounds like a refresh issue and the file was there all along. If that is not the case, please check the permissions for the file and the containing folder
Rick
