Handling of XMP sidecar files
breydi
Post by breydi »
Like many of us, I'm shooting JPG + RAW, RAW being CR2 or ORF in my case. I'm using JPG as file being displayed in XNView MP with the RAW file as sidecar.
My Problem:
Only the .JPG.XMP sidecar file is updated, but not the .RAW.XMP.
This is the same issue that was highlighted in this post viewtopic.php?f=96&t=29532&start=30#p153989, but it looks like it has never been resolved.
My first assumption was that when adding {ext}.xmp to the sidecar configuration ([jpg | cr2;orf;{ext}.xmp]) it would help, but this doesn't work, still only the .JPG.XMP is updated.
Is there any other solution that I did not find?
If not: Is there any chance to have this (Update of all related XMP sidecar files) implemented?
Regards
Dirk
