Installation of XnViewMP 0.96.4 in Linux Mint 19.1 works fine, apart from the font-size of the thumbnail labels. These are much larger than fonts of the menu bars and the fonts in the tree panel. The font size of the thumbnail labels is much too large, practical unusable.
Is there a way to fix this nasty problem?
Font size of thumbnail labels
Re: font size of thumbnail labels
settings>Thumbnails - appearance
pubota
Hi, it seems this cannot change the font size at Thumbnails + Details view. The details text is still kept very small. Is this by design ? Thanks !!
rnmerchant
I have the similar but opposite problem - the details under the thumbnails in the browser view are all too large (albeit not a huge problem). I've used the "-noDpiScaling" option in the shortcut, and gone to 'settings-thumbnails-labels' but I find no way of adjusting fonts/font size.
Under 'options-view-info' there is a setting for fonts which allows font size but I've not yet found what that does - it doesn't seem to do anything to the interface.
Other options mentioned on the Forums don't seem to address the issue.
Any suggestions? Thanks
I also found the font size unusually large in 0.98 [Linux] and there is a setting to change it:
Tools > Setting > Browser > Thumbnail -- Appearance tab,
Then click on the font currently selected to bring up font settings including the font size...
Quite well hidden...
rnmerchant
Late response... Settings - thumbnail - appearance indeed worked to fix my problem. I don't know whether I didn't notice it because a weird MSfont with name shortened was there and I didn't recognize it as a font! Anyway all better now.
Thanks Pierre! Happy 2022.
Richard
Richard
