XnViewMP 0.96.4 (and older) hotkey problem
Dimoniusis
Post by Dimoniusis »
- XnViewMP 0.96.4 (and older)
- Windows 8.1
- Fullscreen view
1) PgUp and PgDown select next / previous file in folder. Arrays left-right do the same
2) I switch by Alt+Tab to other app then return to XnView with Alt+Tab again
3) PgUp and PgDown change files but NOT a previous / next (skip a bunch, show every 20 photo). Arrays left-right work fine. Switch to explorer mode by enter and return to fullscreen view fix that till next alt+tab.
Re: XnViewMP 0.96.4 (and older) hotkey problem
you means that after returning to XnView (with ALT+Tab), PgUp/PgDown are no more working?
Dimoniusis
xnview wrote: Tue Aug 11, 2020 9:16 am you means that after returning to XnView (with ALT+Tab), PgUp/PgDown are no more working?
Working, but different way. Not change next / previous image, switch to every 20
is it the fullscreen from browser (F11)?
Dimoniusis
From explorer it opened default as fullscreen view.
I record video: https://www.youtube.com/watch?v=fdVNyEpbFiM
If i enter to xn-explorer view and then back to fullscreen view PgUp/PgDw work good again.
Dimoniusis wrote: Wed Aug 12, 2020 4:40 pm From explorer it opened default as fullscreen view.
ok, do you use 'Fullscreen browser' in settings>General - Mode when starting...?
Dimoniusis
Mode when starting with a file - Fullscreen - Browser
i'm not able to reproduce on windows 10
