option to define the max. amount of image tabs
klumy
Post by klumy »
XNView 1.91.5
Windows XP SP3
Re: option to define the max. amount of image tabs
klumy wrote:option to define the max. amount of image tabs
Why? And what's happened if you exceed this limit?
klumy
Post by klumy »
sometimes there are too many tabs. you can't see them properly.
so I think a limit would be useful, as well as an option to order the tabs in multiple rows, if there are too many tabs to display them in one row
XNView 1.91.5
Windows XP SP3
