1/ Open XnViewMP 0.96.4
2/ Open any image
3/ Click on the crop icon
4/ Select some crop scaling, for example 16:9
5/ Close the image
6/ Select an image
7/ Click on crop icon.
Notice that eventhough you didn't close XnviewMP, the last used scaling crop is not used, but it defaults as free cropping.
Suggestion.
When clicking on the crop button, it is possible to add/delete crop scalings by click on button "..."
Add an option :
"default to last used cropping" YES/NO
or
"default as free cropping" YES/NO
Thanks
Crop default loose scaling between session - 0.96.4
mustbeit
