German translation: Ganzer Bildschirm vs. Vollbild
In the German translation there are two trems used: "Vollbild" and "Ganzer Bildschirm" for the same thing. Perhaps there should be just a unique expression (Vollbild is better)? Eg: View a single file and the Ansicht-> ganzer bildschirm and some more if I remember right
Re: german translation
Right, Thomas, currently that's a bit of a mixture. I'll check and what makes sense. ("Ganzer Bildschirm" is clearer than "Vollbild", I think, but much longer and two words).thire wrote:In the German translation there are two trems used: "Vollbild" and "Ganzer Bildschirm" for the same thing. Perhaps there should be just a unique expression (Vollbild is better)? Eg: View a single file and the Ansicht-> ganzer bildschirm and some more if I remember right
Ja. Aber einmal angeklickt, weiß man auch schon bescheid, oder?helmut wrote:Right, Thomas, currently that's a bit of a mixture. I'll check and see what makes sense. ("Ganzer Bildschirm" is clearer than "Vollbild", I think, but much longer and two words).thire wrote:In the German translation there are two trems used: "Vollbild" and "Ganzer Bildschirm" for the same thing. Perhaps there should be just a unique expression (Vollbild is better)? Eg: View a single file and the Ansicht-> ganzer bildschirm and some more if I remember right
Also mir gefällt Vollbild weit besser, nicht zuletzt weil es der übliche Ausdruck in vielen anderen Programmen dafür ist.
Und ich weiß, dass es kein gr Thema ist, aber es sollte stimmig und maximal intuitiv sein. Auch für allererst-Benutzer (mir war beim ersten Klick nicht _ganz_ wohl und normalerweise clicke ich nicht auf Dinge, wo ich nicht weiß/wissen sollte, was kommt. Ero: bitte ausbessern.
