Import et fichiers compagnons
Re: Import et fichiers compagnons
which filename template do you use? and which companion settings do you have?
fedelin
Post by fedelin »
Filename template is provided above viewtopic.php?p=177109#p177109
Quand ça marche on apprend rien...
.arp sidecar is not defined?
fedelin
Post by fedelin »
Good point I did not checked this out -> it is from what I understand:
it works here, could you paste here the filename template, perhaps i made a mistake
fedelin
Post by fedelin »
{EXIF:Date Taken [ymd_H]}h{EXIF:Date Taken [M]}-{Filename Number}
Crazy, i obtains 5 files, never the duplicate dialog
fedelin
Post by fedelin »
Ok, I will reinstall xnview with all default settings and test the feature again
fedelin
Post by fedelin »
~/.local/xnviewmp removed
-> Menu settings / file list / adding {raw} - .arp + ticking the 3 below boxes
-> Menu tool/import&sort
-> setup source target folder
-> setup destination target folder
-> no subfolder, no filename renaming
-> ticking "transfert file with no EXIF to 'Other Files' folder
=> launched : companions files correctly moved to an "other files" folder (meaning to me they are well identified)
-> unticking "transfert file with no EXIF to 'Other Files' folder
=> launched : companion files not moved (F... !!! What do I miss here ???)
fedelin wrote: Thu Apr 28, 2022 4:14 pm ~/.local/xnviewmp removed
do you have modified the companions config?
