Automatically refresh Uncategorized
bezhukov
Post by bezhukov »
I'd like to have the Uncategorized view refresh automatically as I tag items, or at least on refresh (F5).
Is that possible?
Currently, F5 leaves newly categorized items in the Uncategorized view. The only fix I have is select "Special Items/All", then back to Uncategorized.
Thanks!
Re: Automatically refresh Uncategorized
you means that if you use 'Uncategorized', and tag some items, they stay here?
Phil_Rose
Post by Phil_Rose »
I agree and I'd like to see that for all categories so, for instance, if I have the filter set to Uncolored and it shows all my files (as they are all uncolored) and then I color one of them Blue (for instance) I then have to hit the drop down for filter and hit Uncolored again to update the view. ACDSee and Exposure X5 both automatically and immediately remove an updated image from a view upon change.
yes need to update following the filter
bezhukov
Post by bezhukov »
Correct. I guess it makes sense as long as the pictures are still selected, though ideally a refresh would deselect and hide if the filter is Uncategorized and you just added categories to selected, then Refresh.
As it is I have to select Tags or All under Special Items, then reselect Uncategorized. Then the newly categorized disappear.
This is XnView MP Linux Version 0.99.7 64bits (Jan 13 2022)
Now F5 works correctly, to update current file list
