I'm using XnView MP Linux Version 0.96.4 64bits (Jun 30 2020) under KDE Neon 20.04 focal (KDE 5.72.0 / Plasma 5.19.4). I'm seeing two major issues; one is a recent problem, the other is long-standing in every version of xnview linux I've ever used (several years now).
1. After updating from a previous version, the "Open With" external program assignments no longer work. They do not open any program now do they provide any feedback... just nuthin. I've removed and reprogrammed them with no joy. I've checked the config file and all seems to be in order, but nothing is working here.
2. The "Open with File Explorer" function has never worked in Linux. This has been true for me over many versions of xnview and several different distros.
QUESTIONS:
Are these known issues?
Will they ever be fixed?
Are there any work--arounds?
Thanks!
External programs not working in Linux
CrustyCurmudgeon
OS: KDE Neon 20.04 focal
Kernel: x86_64 Linux 5.4.0-47-generic
DE: KDE 5.74.0 / Plasma 5.19.5
CPU: AMD Ryzen 7 2700X Eight-Core @ 16x 3.7GHz
GPU: Radeon RX 570 Series
RAM: 32 GB
RAM: 32 GB
Re: External programs not working in Linux
check terminal, perhaps a Qt version conflictCrustyCurmudgeon wrote: Sun Aug 16, 2020 12:37 pm 1. After updating from a previous version, the "Open With" external program assignments no longer work. They do not open any program now do they provide any feedback... just nuthin. I've removed and reprogrammed them with no joy. I've checked the config file and all seems to be in order, but nothing is working here.
no problem here on ubuntu2. The "Open with File Explorer" function has never worked in Linux. This has been true for me over many versions of xnview and several different distros.
CrustyCurmudgeon
"check terminal" tells me absolutely nothing. "Qt version conflict" with what? How would I identify & resolve such a conflict?
Def a problem on past ver. of Linux Mint, past & current vers. of KDE neon, and past vers. of a few other ubuntu/debian derivatives.no problem here on ubuntu
RAM: 32 GB
RAM: 32 GB
start XnView from a terminal, and check message when you start external app
CrustyCurmudgeon
That's a bit more helpful. I did just that and I did see a Qt error, referencing some "Qt version 5.14 not found" (I am running Qt 5.14.2). Neither the open with file explorer or open with external program worked.xnview wrote: Thu Aug 20, 2020 7:23 am start XnView from a terminal, and check message when you start external app
I then checked for updates and saw a minor update available (0.96.4 >> 0.96.5) so I updated. Now, external programs are working as they did before. However, "open with file explorer" does not work. It shows the same error:
"kde-open5: /opt/XnView/lib/libQt5Core.so.5: version `Qt_5.14' not found (required by kde-open5)"
followed by several others referring to different files.
However, Qt 5.14.2 is currently installed. What is the problem here?
RAM: 32 GB
RAM: 32 GB
CrustyCurmudgeon
anything at all?
RAM: 32 GB
RAM: 32 GB
it seems that there is problem with paths for QT libs, XnView MP use QT 5.12
CrustyCurmudgeon
Okay. So where might that "problem with paths for QT libs" exist? Considering that I'm using KDE as my primary desktop OS and it's pretty reliant on a functional QT foundation, I would suspect the problem is with XnViewMP Yes? No? Suggested troubleshooting steps or fix?xnview wrote: Mon Aug 31, 2020 1:43 pmit seems that there is problem with paths for QT libs, XnView MP use QT 5.12
RAM: 32 GB
RAM: 32 GB
CrustyCurmudgeon
Just updated to Version 0.97.1 64bits (Oct 14 2020) and wanted to note that all "Open with" external programs are now functioning, including the "Open in file explorer" (be still, my beating heart!). That said, there seems to be an issue with the XnViewMP call the to the file explorer. In my case, it's Dolphin.
- When I already have Dolphin open on my desktop, the "Open in file explorer" in xnviewmp opens a new tab in the existing Dolphin session. It's perfect. HOWEVER,
- If I do not have an existing session of Dolphin running, I get a strange new dolphin window with no icons and an X11 icon in the window corner (as opposed to a normal Dolphin app icon). Also, there is no list of files, as if it were filtered, but it isn't. "Show hidden files" is enabled and there are files in the folder that should appear, but do not.
RAM: 32 GB
RAM: 32 GB
