Needing some help about XnviewMP database structure
Gwenael Q.
Post by Gwenael Q. »
I would like to be able to modify the tag database of xnviewmp directly, without having to use the xnviewmp interface, still not fully mature IMHO.
In XnView.db, the "Tags" table has the following fields :
- TagID : OK
- Label : OK
- ParentID : OK
- ID : ????? very often with "0" value but not always
- Hidden : OK
- Description : OK
- Shortcut : OK
All fields but one are quite self-explanatory but I didn't manage to understand the the function of the "ID" field. Any suggestion ?
Thank you very much by advance
Re: Needing some help about XnviewMP database structure
Gwenael Q. wrote: Tue Aug 18, 2020 1:47 am - ID : ????? very often with "0" value but not always
this filed is no more used...
Gwenael Q.
Thank you !
