Is there an option to share configuration (or more specifically labels in thumbnail view) between multiple (Windows) machines?
Share configuration/labels
Re: Share configuration/labels
yes, if you use export in XMP metadata
_lion
Will check that, thanks.
If you are talking about settings of xnviewmp 's screen, see in xnviewmp.ini file...
Catalogage avec XnviewMP :
