Keep in Browser mode after pasting file path on address bar. Possible to set it up, even by editing xnview.ini?
cadu
Post by cadu »
I'd appreciate your help.
As shown in this screencast (https://bit.ly/2Qo7kpM), when I paste a file path (e.g. C:\Image\Image.jpg) on XnViewMP 0.96.5 it launches the file, leaving the "Browser" and changing automatically to the "Viewer" interface.
I perused XnViewMP settings and couldn't see any explicit option to "Keep in Browser mode after pasting file path on address bar".
As a reference, I'm trying to achieve in XnView the default behavior when you paste a file path on Adobe Bridge address bar.
Does anyone know if it is possible to set up that behavior editing xnview.ini?
Thank you very much!
Carlos
Rick
Re: Keep in Browser mode after pasting file path on address bar. Possible to set it up, even by editing xnview.ini?
Post by Rick »
Settings / Interface / Tabs
Set the number of tabs down to one and see if that helps
Rick
cadu
Post by cadu »
Rick wrote: Wed Aug 26, 2020 7:49 pm Settings / Interface / Tabs
Many thanks for the suggestion, but unfortunately, it doesn't stop XnView of launching the file in the Viewer mode. It seems the "Browser" tab isn't counted as "one".
